Hi All,
I just joined. My BX 1800 is not cranking over, so not starting or even trying. This happened a couple months ago also. I checked the safety switches, the one for the neutral and pto, with a meter, checked ok. I just called the no help Kubota shop, said it could be the ignition switch, or the seat switch, it doesn't have a seat switch, or he said it could be the brake switch, don't think it has one, but done know. Then he said it could be the starter. Then he said I could bring it in. I could almost bet an undisclosed amount of money it would start every time.
Last time this happened, after fooling around for over an hour, I was sitting on the seat, thinking what I could try next. Hit the key, and was moving the pto lever and it started. Till now, been cranking every time.
Just got to thinking, I am doing the same work now as the last time, getting ready to clean out the barn, nearly the exact same spot on the ground...
Thanks for any thoughts!
Jim Guerin
Yelm, WA
Jim Guerin
Yelm, WA
