Buying advice 50-60 HP
Testedone
30
Tennessee
Let me state what I am looking to do first
  • Rotary cutter work - want a 8 foot dual spindle
  • Loader work - widening my trails - clearing dirt and generic "dirt work"
Now let me state what I "think I want" in the tractor itself
  • Used
  • 4WD - Must have that as I have some hills in the holler
  • keeping in mind I have hills I am told there are "narrow" models, need to stay away from them
  • HST - not sure on this, I liked using my neighbours JD2950 with 8 FWD and 8 Rear
  • don't need a Cab
Probably missed other things but though this would get some ideas going. Since I am not familiar with the Kubota brand thought to ask here.
Thanks much
russell.still.5
197
Lafayette, Alabama
I would recommend a Kubota M6040 or M7040. it’s going to take a good bit of HP and weight to handle an 8’ cutter. I had a M7040 and without the Loader or Front weights the front tires were barley on the ground.
That being said a M5040 M6040 and M7040 are the same tractor with different engine tuning and tires.
japollner
BX2380
Jul 23, 2018
58
GREENFIELD
I'm not well versed in the bigger stuff, and buying used is going to hinge on what your local market is like, but you might be able to find a used MX5800. That's about the smallest tractor you'll find with the power you want.
Your next step up is going to be the M series. 6040 or 7040 like Russell recommended. If more fields work, the M would be good. If you are going to be working in the woods as well, the slightly smaller MX might make more sense.
Here's a great video from Messick's talking about the differences. https://www.youtube.com/watch?v=QbWem2lgf04
Testedone
30
Tennessee
yes I was looking at a 5640SU, how are those compared to what you mentioned
russell.still.5
197
Lafayette, Alabama
5640SU is a stripped down,bare bones, version of the ones I mentioned. I believe it is the same tractor without some of the creature comforts. I would rather have the extra horsepower of the M7040 since there is really no difference in size and weight. If you get an 8ft cutter you will need that extra HP sooner or later.
I posted in the 5640SU thread too. I have a Kodiak 8ft Cutter and it makes my M9540 grunt sometimes.
Testedone
30
Tennessee
I was told a dual spindle wouldn't have it (tractor) work as hard or weight as much, urban legend??
russell.still.5
197
Lafayette, Alabama
I’m not sure about being easier to pull or being lighter, but they are shorter and will not scalp as bad. Since they are shorter they will be easier for the tractor to lift because the weight is closer to the tractor. I have never seen an 8 ft single spindle but have seen a 7 ft single spindle and it was huge.
I looked at the specs on a Land Pride single vs dual spindle 7 ft. The dual spindle is heavier by 50 lbs. The dual spindle is 80” overall length and single spindle is 135” overall length.
Single
https://www.landpride.com/ari/attach/lp/public/specs/312-880s.pdf
Dual
https://www.landpride.com/ari/attach/lp/public/specs/326-355s.pdf
SDT
multiple and various
Apr 15, 2018
3,375
1,161
SE, IN
  • Used
  • don't need a Cab
Thanks much
Give up on HST if you want to pull an 8' mounted cutter. You will not find a 60 PTO HP HST, and 60 PTO HP is marginal for an 8' mounted cutter.
I agree with Russell that you need the HP of the 7040 (or 7060) for your mower of choice, but be advised that used ROPS models are not common.
Forget about the 5640SU. Though it is marginally heavy enough with front weights, it uses the same 148.5 CI turbocharged engine as used in the MX5800 and L6060. This engine produces no more than 53 PTO HP in the L6060 (a bit less in other models). This is not enough for an 8' cutter.
If your heart is set on an 8' mounted cutter, I would recommend nothing smaller than the 7040/7060.
SDT
SDT
Apr 15, 2018
3,375
1,161
SE, IN
Single
Dual
8' single spindle cutters have been made but are rare and even longer than 7' ones.
I certainly would not want one.
SDT
BAP
Dec 31, 2012
3,076
1,201
One thing you mentioned was that you liked your neighbor’s JD 2950. Keep in mind when comparing that to other tractors is that the 2950 is a 85 HP and around 10,000#. Big difference in operation
Testedone
30
Tennessee
yes and he said with that big frame and weight is why it road nice on his beat up cow pastures
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,137
852
Wellsville, PA
My son runs a M7060 pulling a 8' dual spindle and it works great. I borrowed it a couple times before I bought my Kubota when my old IH 540 hydro went belly up :D If you can afford a tractor with 65 PTO hp you'll be good to go.
Good luck
SDT
Apr 15, 2018
3,375
1,161
SE, IN
My neighbor has a 2950 JD with 4X2 power shift transmission and FWA. He pulls a mounted Bush Hog 10' cutter with it.
The JD is a farm tractor. It's a bit of a dinosaur these days but is a real worker.
SDT
