Bush hog chains
Jms63
Mx6000
Oct 17, 2021
51
17
Alabama
Just had a dealer quote me $490 to put chains on a 6ft titan bush hog….and I was going buying the bush hog from him🤨
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
That’s cheap. Was told it’d be $700 for rear chains on a bush hog 316... it’s still rocking the metal guard. I will remove once it’s completely bent and mangled.
SDT
multiple and various
Apr 15, 2018
3,399
1,181
SE, IN
They're not cheap.
If you decide on chains do rear only. Front chains allow too much debris to be thrown onto the back of the tractor.
Jms63
Mx6000
Oct 17, 2021
51
17
Alabama
They're not cheap.
So you like the belt up front ….. not going to use anything on rear…. With belt up front do you get a good cut ? I thought that might hurt my airflow with the blades sucking the grass upwards seems to make a better cut..
Jms63
Mx6000
Oct 17, 2021
51
17
Alabama
I had no idea one set of chains cost that much🤨
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I just replaced my worn out front belt....thankfully. It was piling debris on the back of the tractor without it. I have nothing on the back.
I use discarded hay baler belt.
10,108
I went with factory chains front and rear on the LP RCR1884 with no regrets, but given the cost, I would think it wouldn't be hard or expensive to make your own chain guard.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,444
1,740
Kalamazoo, MI
They're not cheap.
I use a leaf blower on the tractor and cutter after each use.
SDT
Apr 15, 2018
3,399
1,181
SE, IN
I blow all of my tractors off with compressed after each use before putting back inside.
I've used both and there's much less to remove with front belting rather than chains.
SDT
