Buhler front end loader
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
229
216
Bella Coma BC Canada
Howdy Gang.
The right side hydraulic ram's rear fitting is hitting the front tire
Left side is fine
looking at the two pictures
On the top of the Right side main arm (where the Buhler name is) looks lower than the Left's sides arm
is there some adjustment or is the frame twisted?
Thanks
Hank
Pony Doc
SSV75 Kioti LK3054 Oliver 1250
Dec 15, 2020
35
20
Central Colorado
The position of the FEL arms relative to the hood looks different right versus left. But again this could simply be a photographic illusion, like the tire size anomaly. Consider parking it on flat, level ground, such as a concrete slab, and checking measurements and angles to see if the lift arms and frame components are symmetrical
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,498
2,092
WestTn/NoMs
Howdy Gang.
Left side is fine
Thanks
Hank
Looks to me like the rear pivot of the boom lift cylinder on the right side is below the top of the tire, while on the left it's above the top of the tire.
Park it on a flat slab and measure down from the pivot points and compare.
PonyDoc beat me to it. At least we agree.
BigG
Sep 14, 2018
1,951
774
West Central,FL
Before you start measuring you need to level the tractor. Might need to adjust the tire pressure to make everything level or parallel to the concrete slab. Then start with the attachment points are equal distance from the ground. Also measure the diameter of the 4 wheels. They might be the same size on the sidewall but they could be out of spec or different brands or worn unevenly.
Then check to see if the bucket edge is parallel to the concrete.
DaTow'd
Aug 13, 2013
229
216
Thanks Guys I'll stick it in the shop as soon as it gets free
cheers
Hank
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,050
Williamstown Ontario Canada
If you look at the Buhler manual I think the reason for the problem is as simple as the "BOOT" on one side is not sitting correctly.
If you look at the Removed from tractor and Installed on tractor I think one side of the loader is mounted correctly and the other is not.
The loader needs to be disconnected and then re-installed.
See attached Buhler manual
Dave
mikester
M59 TLB
Oct 21, 2017
3,955
2,622
www.divergentstuff.ca
I'm guessing that one of your problems is the front wheels are not made for that tractor.
I had the same loader on my L245, should't ever come close to hitting the wheels. Either your mounts need to be adjusted or the loader frame is bent.
DaTow'd
Aug 13, 2013
229
216
We have two Kubota tractors with the same size front wheels L185dt and 2202dt
How do these mounts compare with mounts on your Buhler front end loader?
Hank
