BT900 Refurbishment and fun - PART 2
Nicksacco
Kubota L35 TLB, 2014 RTV-1140CPX
Sep 15, 2021
701
421
Bahama, NC
Howdy All-
I've been delayed due to some projects around the place, but going back to the BT900 to complete the refurb.
I thought I'd again share what I've done to share what I've learned and the tools I'd used.
In this PART 2, I am replacing the bushings in the backhoe frame that are the BOTTOM and TOP supports for the swing cylinders. There is a very heavy steel bar that goes on the top (where the bushings are pressed) and is held in place with 4-14mm bolts
At first (don't laugh) I thought I could bang out the bushings from the bottom. I was wrong - so wrong.
Using my plasma cutter, I carefully cut several slots down the length of the bushing and then banged them out from the bottom. Yea Plasma Cutter! it took about 15 minutes.
For those of you that are planning something like this - note that the bushing sits on a ridge in the collar. Thus you can only bang it out from the bottom,
Before going further, I cleaned the threads using a 1/8 x 27 NPT tap and a tap holder. These tap holder sets are very handy and I got mine on Amazon. CORRECTION (I HAD 1/8 X 37 WHICH WAS INCORRECT)
I started the new bushings (which I froze in my freezer) with a hammer (barely room) and then used a little home made bolt press to pull the bushing down. This works, but getting everything ready to install, the bushing loses that cold really fast. I used a 48mm bearing/bushing press disk. I used a 9/16 Grade 8 bolt and nut to do the pulling. You also need to buy Grade 8 washers Regular steel washers will deform!
This is the bushing/bearing kit I found on Amazon.
Completed new installed bushing. Remember to line up the grease hole in the bushing with the grease nipple!
This is the new bushing part number. You will need 2 on top and 2 on bottom. Note the 48mm disk.
This is the TOP rail after removing the old bushings. Someone before me really had fun here - note the scratches.
I cleaned them up with a sanding drum.
Nicksacco
Sep 15, 2021
701
421
Bahama, NC
Using my Dremel and a wire brush, I cleaned out the threads on the top bar.
The Top Bar will get a powdercoating next. More to come.
Nicksacco
Sep 15, 2021
701
421
Bahama, NC
Hey @fried1765 ! Under certain circumstances powder may not be recommended.
However, with proper prep and such, it's pretty durable. The top bar won't see any tough life, being protected by living inside the backhoe frame. The powder kind of seals everything so I don't expect an issue.
To be certain for stuff like brake rods or other things, I will often use a powder primer under the color coat.
Nothing is impervious but it seems to work so far.
@PoTreeBoy the Part One of the BT900 refurb is located here
Thanks y'all for reading this
