Bt820 bh77 subframe
louis2650
9
Garrett,IN
Does anyone know if a bt820 backhoe will fit on a bh77 bh4962 subframe. I have a b2650 and have a chance to buy a bt820 kinda reasonable. I would just need to buy a subframe.
8,756
They both have the same general design of mounts, but the chances of it being a direct fit are low.
The BT820 was only used on the B26, they do not list a separate mount, as the mounts are part of the ROPS and framework of the B26.
The BH77 is actually smaller than the BT820 so you would be getting a larger backhoe that might over power the tractor.
Hopefully your modification tools and skills are up to par, and then yes I think with the right mods to the mounts it should work fine as far as fit.
One thing to keep in mind is that your tractor has less Hydralic flow that the B26, looks to be only 2 GPM differance but that little of a differance can make a big BH a lot slower. ;)
louis2650
9
Garrett,IN
Ok thanks I was doing some general side by side measurements and the look really close. Do you think I should just wait and pass this up?
8,756
If the price is right I wouldn't, but then again I like modifying and adapting implements.
ttpp
15
CA
I have a 2010 B3030 with cab & got lucky & stumbled across a early 2003/4 John Deere 48 hoe that was REAL cheap due to a couple of repairable issues & needing to be modified to fit the factory subframe mounts for the Kubota backhoe.I'm lucky & can make anything I needed to get it to fit .
So if price is right & you can do the rest(and enjoy it)give it a go & if it doesn't work out make sure you don't damage the hoe it's self & you should be able to get money back
Sent from my SM-A520W using Tapatalk
