Bseries 2620 running rough
Aaron H
canada
Hey guys so my tractor will start up great, run great for 5 mins then it will bog right down and most of the time just stop. It did this about 8 months ago and I still havent gotten it fixed. I changed the filter already. I also disconnect the fuel line after the filter before it goes into the pump and the tank drained out just fine without any interuptions in fuel flow. I thought maybe I had an air leak or something so I took the filter out and cleaned out the fuel lines before the pump. It ran actually alot better than it did the other day thinking that fixed the problem but it is still dieing out on me. I have no idea where to start looking. Any help is great, thanks
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Loosen your fuel cap and tape it in place loose, and give it a run, in case it's not venting properly.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
I ended up having to pull my fuel tank. Someone dropped a foil seal into the tank.
Sent from my XT1650 using Tapatalk
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Well at least it's sorted now and the cure was minor compared to an injection pump cost etc.!
