Briggs and Stratton 15.5HP engine running loud
koja
BX25D
May 27, 2014
335
Fremont Mi.
I wouldn't worry about it ,,,,,,,its a Briggs . The last Briggs I had was a 1979 16hp in my previous garden tractor . It knocked for the last four years I had it . That old engine had almost 4000hrs on it . Ran great, smoked a little, knocked some too but was still the same when I sold it last year .
10,194
I wouldn't take it on any road trips! :D
I'll have to post a video of my 1980's Simplicity with a 10HP Briggs, it smokes more than a Southern BBQ!
Can't get parts for the motor and can't get a rebuild kit either, so I have a 16hp Honda that's going to replace it.
Tooljunkie
May 13, 2014
4,150
34
Change oil to 30w and run it.
Rebuild or replace, same money. Especially if you pay a shop to do it.
My mtd knocks too.
Bought a new one 3 years ago, dont regret it for a second.
9,062
My old roommate had an ancient briggs and stratton in a self propelled push mower. Never checked or changed the oil in it and smoked like a chimney :rolleyes: seized it up one day doing the yard. I pulled the plug and started soaking the top of the piston with some hilco lube. After soaking for about 5 days morning and night, i took a wooden dowl and layed into the cylinder with the dowl and a bfh. Got it to free back up. Dumped the oil out of it. Put in straight lucas oil treatment instead. Filled it up with gas and gave the pull cord a yank. Darn thing fired up first pull :eek: after about a minute it quit smoking. Guy still uses the darn thing to do his yard :rolleyes: I fixed it for him 15 years ago :D
jimadd
29
SC
My dad used to work on lawnmowers and stuff when I was a kid....many many moons ago. The biggest problem with over half the ones he would work on that sounded as if they were knocking had carbon build-up on the pistons. He would always ask if they let it idle a lot and if so that was bad for them. They were meant to run wide open to keep the pistons clean and keep them cool as they were air cooled.
I would pull the spark plug and take a small light and look at the top of the piston and see if its caked with carbon. You can also check the play of the piston at top dead center if it is a loose rod or piston pin. Good luck on it.....
clippy
Kubota B6100D w/ Kubota FL1000 Tiller, Kubota Bedder, Brush Hog Mower
Thanks for the responses everyone. I kind of thought it was more knock than muffler. I don't really have the time (or skills for that matter) to dig into the engine. If it had been a muffler I probably could have (relatively easily) replaced it. I'll probably run the poor thing into the ground. It would be interesting to see how much life it has left.
