Brand
tjborowicz
12
Flushing Michigan
Anybody have anything to say on what brand of implements to buy? Good or bad. I wanna know what to stay away from. Landprides kinda look cheap to me online but I don't have any experience with them. In the past I know woods has made good stuff, do they still? Gonna be getting pallet forks and a rear blade right now
mickeyd
Mar 21, 2014
1,192
Guin, AL
Land Pride has more than one level of each item.
I have a LP cutter, tiller and pallet forks.
I had to go with the 18 series cutter as like you, I felt the 12 series was a little lite.
The tiller has been fine and the pallet forks is as good as anyone's.
I have some King Kutter implements and they are built well but don't have the finish of LP but cost less.
4,057
Check out Everything Attachments free shipping for 1000 miles I think and I havent head anything bad about their stuff
Mainah
L2501HST, BLMX3164 blower, BB1266 box blade, BX42S chipper, Titan forks
Feb 26, 2018
100
Standish, Maine
Another vote for Everything Attachments. For forks Titan has a great price and free shipping also.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Land Pride and King Kutter are both American made.
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Whatcha hooking up to?
My LP rear blade RB1560 is a beast, perfect for my B2710.
My LP Grading Scraper GS1560 is also heavy duty.
I would definitely buy LP implements again.
NoJacketRequired
May 25, 2016
431
71
Ottawa, Ontario
One specific observation on box scrapers...
I have a 5' Bushhog box scraper and a 4' AgriEase box scraper. The AgriEase product is a far, far heavier-duty implement. The 4' scraper from AgriEase is considerably heavier than the 5' Bush Hog product even though it's only 80% as wide.
MtnViewRanch
868
305
Lakeside Ca.
Almost every implement-attachment manufacturer have several levels of equipment that they sell. Land Pride builds equipment to fit behind an 18hp BX up a 168hp M 7 series and everything in between. If you looked at one of the lower levels of equipment to use on a bigger machine, I could see that you might think that something was a bit light duty. Look at a heaver level of implement and I believe that you will change your mind as far as looking cheap. ;)
eipo
L4060
Dec 1, 2015
699
85
MI
Ive got a box scraper from TSC. Made by Tarter... It does what it needs to do for my residential yard and I wouldn't hesitate to use it anywhere behind my 2650. I cant envision needing anything heavier for this particular tractor. Ive got hundreds of hours on a box scraper via my employment building landfill cells.
My rear blade and land plane are Woods. For no other reason than timing and convenience when I purchased them. I forget the model on the rear blade, but it does tilt and side shift.... Its decent and has served me well spreading ground asphalt and plowing snow.
My Tiller is from TSC, also made by Tarter. It too does what it needs to do behind my tractor.
My Landscape Rake is EA.... Bought specifically from EA because the quality to dollar ratio was much higher than anything I could get locally. If I had to do it over again, all my attachments would be EA.... They've put a fair bit of thought into their stuff in relation to everything else out there, and do it at a much better price point.
AndyM
BX25DTLB
Sep 21, 2016
514
168
Vancouver Island Canada
I cannot offer a comparison but can say the AgriEase box scraper I have seems quite robust.
pak
24
NE, Wa.
I got a bucket, pallet forks and a front mounted snow blower with my tractor when new. I think these are Kubota products. All are well constructed units and have performed very well. I have a backblade by Land Pride. It is well made also. I see other back blades that have an offset so you can blade outside the rear wheel track. KK makes one and I would rather have one than the one I have. My bush hog is made by Bush Hog, again it is well built. I also have a Land Leveler by Everything Attachments this unit if anything is overbuilt and is reasonably priced for this quality. EA has a very comprehensive website with many videos. I will be buying from them again. I also have a set of Pat's 3pt quick attach fittings. Wouldn't be without these. I also have the QA on the front. My tractor is a B2601. Buying attachments is a slippery slope
