Bought my first one ZEN NOH ZL1501DT
Dog Trot Acres
ZEN-NOH ZL1501DT with a 1846QT BUSH HOG frontend loader, 4 ft BUSH HOG
Jun 29, 2018
10
Millbrook, Alabama, USA
Recently bought a ZEN NOH ZL1501DT tractor from a guy. It has a Bushhog brand frontend loader model 1846 QT mounted on it. I got a 4 foot bushog, 5 foot finish mower, 4 foot box blade, and a ripper blade. The tractor has 3047 hours on it. It runs good. It is not pretty but I didn't buy it for looks. We just bought 3 acres to build a HOMESTEAD on and that is what we plan to use it for. I am planning on doing a oil and filter change, fuel filter change, air filter change. Going to grease all of the grease fittings and give it a good pressure washing. I plan on using engine degreaser and then pressure washing it too. I have all ready installed a new battery, sharpened the Bushhog blades, installed a new muffler with flapper valve cover. It has a set of external aftermarket gauges for voltage, oil pressure and temperature. The oil pressure gauge had a leaking line. I fixed that. It has good pressure. I plan on rewiring the whole tractor and moving these gauges into the stock dash bezel. I also plan on adding all led work lights, replacing the stock headlights with led, a small led light bar, plus the red and orange safety lights on the back fenders.
Other then the maintenance I listed is there anything else I should do/check on? Any help with this would be greatly appreciated. I will post so pics as soon as I get enough posts.
8,726
A lot of issues come out of pressure washing, things will start to leak that never did.
Gaskets can be dislodged, O-rings damaged, Seals ripped and injecting water into things that shouldn't get wet.
Also it's very hard on the radiator fins, and the wiring.
Dog Trot Acres
Jun 29, 2018
10
I guess I should have said I am going to use the low pressure part of the pressure washer the one that sprays cleaner. Then hose it off. Pressure WASH the body and chassis.
