Bolt Pattern and Hub Diameter for B7500 wheels
tsp159
B7100D
Feb 8, 2023
102
56
Fort Bend Texas
Does anyone know the bolt circle and hub diameters for the B7500 wheels? I found a decent deal on a set of R4 takeoffs mounted from a B7500 and I want to see if they'll fit on my "new style" B7100 with the 6-lug hubs.
As best I can tell, the fronts are 4.5" bolt circle with a 2-5/8" hub hole and the rears are a 6" bolt circle with a 4-5/8" hub hole. Obviously, precision measured with my worst tape measure.
tsp159
B7100D
Feb 8, 2023
102
56
Fort Bend Texas
So my deep Google dive seems to indicate that the B7500 front wheels for the turf application Part #6c040-50640 have a larger bolt circle pattern and hub pilot bore, with 6x4.72 and 3.5" respectively. However, it looks like the B2150/B8200/B9200 had an option for turf front wheels that would be spot on. 6x4.5 with a 2.74? hub pilot bore. Interestingly, the Google searches resulted in this little reference image found here on OTT from a few years ago. Kubota Part #32711-57420
I've also found another ancient thread here on OTT where another member had some 14" fronts off a newer machine (B26?) that has the same 6x4.72 with 3.5" bore and had his wheels slotted and a new pilot bore spacer/bushing machined.
I'm tempted to make a deal for the "wrong" wheels and try something like option #2 - but I might look for an adapter rather than machine the wheel out. More wider is more better, or something like that.
N3BP
Sep 20, 2016
481
208
Lebanon, PA
I believe the bolt pattern is identical for all the older b-series that are 6 bolt. The rears for both machines should be lug-centric, and the fronts hub-centric. So the front hub fitment will be critical.
