Blue/white smoke at startup.useTe
Daniel Pullum
B3200
Aug 7, 2022
26
Decatur, Illinois
I have a B3200 purchased new March 2011, currently has 1180 hours.
I always run the glow plugs for 10 sec when cold starting. It blows "blue/white" smoke until it idles out. It does not show smoke at any other time.
I was told at one time, it is oil draining down thru valve guides oil into the cylinders.
Should this be addressed?
Jsjac
B2650
Feb 13, 2022
205
330
It most likely is incomplete combustion. until the cylinders warm up enough to completely burn the fuel injected
8,704
It's not the valve guides.
It's more likely, tired glow plugs, or tired injectors, or little lower compression than new.
Put some new glow plugs in it and the issue will probably go away.
