Big problem with my loader LA344
sevfit
Today while removing my loader it got snagged under a rubber mat and ended up engaging some dirt/stones as I was trying to remove it from the tractor. As a result I had a very botched removal and the end result is that the couplers on the loader will not reach the couplers on the tractor. Is there a safe way I can jack up the loader arms to align the quick connect couplers. I was thinking a Jack Stand. Any suggestions would be very welcome.
5,959
Today while removing my loader it got snagged under a rubber mat and ended up engaging some dirt/stones as I was trying to remove it from the tractor. As a result I had a very botched removal and the end result is that the couplers on the loader will not reach the couplers on the tractor. Is there a safe way I can jack up the loader arms to align the quick connect couplers. I was thinking a Jack Stand. Any suggestions would be very welcome. View attachment 91268
Engine hoist or another tractor would be my first choice. If you go with jacks watch where you put your fingers.....
My Barn
Kubota, Ford
Sep 14, 2022
135
37
If you have away to use a come along over head? That may work? That way you can get under the loader. Good luck...
ferguson
L3130
Jan 19, 2022
321
125
w.v.
The loader is not that large get a couple of friends a guy on eack arm & one to set the stand legs
leveraddict
Apr 1, 2019
905
593
NEPA
You never put the loader stand down.
Grandad4
Apr 5, 2016
404
153
Greensboro, NC
A couple of strong guys should be able to lift the back of the loader arms high enough so you can release the support stands and hold the arms up. You may need to get that rubber mat out if it is preventing the bucket from tipping forward as the arms are lifted.
Lesson learned: always deploy the support stands first! Not to worry, "stuff happens" to everyone!
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
If you haven't done this yet, I will add one thing. Take the bucket off to make it lighter to lift.
3,288
I’m not sure what that black bucket is doing, but you certainly don’t want anything pushing up on the fully extended cylinder at its mid point. (Easy way to bend the cylinder rod.)
2,477
If you are just wanting the cylinders to move then you can just disconnect the ends of the hoses and move the cylinder by hand.
You could also buy some hoses with the correct connections and use them for extensions between the tractor and loader.
But just getting the loader back up off the ground is probably the best. I would try using a come-a-long and straps from above to get it done
sevfit
thanks everyone for your help. I ended up calling the service guy from my local shop. He came out and did a couple of the things that were suggested here. What was interesting was that something I thought was major and lost some sleep over turned out to be a minor issue. I do have to say I have very helpful Kubota dealership in my area.
