BH 77 backhoe cylinder
vickark
L3200, fel,backhoe,sgr 1060 grapple, boxblade, lp bush hog,post hole auger
Jun 16, 2013
31
The dip cylinder ( middle one) leaks back a bit when I put pressure on it.
There are no visible oil leaks on it.
Could it possibly be the 4-way joystick valve or is it time to rebuild the cylinder.
Thanks
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
429
35
Red Springs, NC
The answer in my opinion is it could be either. There have been post about the backhoes having minor issues that seemed like trash in the system that soon works its way out. Hopefully this will happen for you within the next few hours. So far I have been lucky, mine works great.
Grandad4
Apr 5, 2016
283
58
Greensboro, NC
Is the leak coming from one of the hose fittings or does it appear that the leak is at the cylinder rod itself? Make sure the fittings are tightly threaded. If it's at the cylinder rod, you may have an internal seal that is starting to go bad.
A hydraulics shop can do a rebuild of such cylinders, usually at reasonable cost, or if you're more adventurous, many folks buy the rebuild kit and do their own.
