Battery Tender
Baby Backhoe Dirtworks
Kubota BX23S, GF1800, and looking to expand!
Jul 20, 2026
20
17
Swan River Valley, Manitoba
Reading through old posts I keep seeing members talking about hooking up to 'the battery tender' all the time. Is this literally just a trickle charger, or a separate product? And is it something some people swear by while others insist does nothing? I've lived in the great white north my whole life, and I don't see anyone talking about noticeably extending their battery life beyond what I'm used to seeing in a pickup or lawnmower, even with starting in extreme cold. We aren't as cold as some places, but we'll still see entire weeks where the mercury doesn't come up above -35* C, which is very close to where Centigrade and Fahrenheit meet (-40*). My BX lives in an unheated garage all winter, and it was been known to start below -30* without the block heater plugged in, under emergency circumstances. It starts happy as a lark in any weather with the block heater plugged in, though I figure it must be plenty of power for such a small block. You'll hear the coolant heat right up in a matter of moments after putting power to it, even in extreme temps. What I need is something to warm to trans hydraulic fluid, it can be pretty icy when I first fire it up.
Jul 20, 2026
20
17
I noticed BetterThanAShovel put a fair bit of work into streamlining the whole 'battery tender' hookup process, which only makes sense to me if it's something one would do quite regularly as preventative maintenance that should save some noticeable money down the road. That said, I'm young and have a hard time finding time to grease regularly and keep fresh oil in everything, and I know many of you are retired or at least have significantly more time to devote to your LOB's (Little Orange Buddies). I'm somewhat jealous, but determined to enjoy the stage of life I'm in. I may be young, but I know life moves through the stages fast enough without hurrying any of them along.
11,543
Those posts hurt my brain!
Do battery tenders help, yes!
Battery tenders are not trickle chargers, they only keep the battery at a max level they don't keep charging when the battery is full.
It doesn't extend battery life as much as it gives you max potential all the time.
It will help from having a battery freeze and ruining it.
Jul 20, 2026
20
17
Sorry to cause you pain NIW. Idaho sees some decently cold temps, right? I looked up where that is, I was thinking south of Alberta, but you're south of BC. Is that close enough to see some pretty serious warmth coming off the ocean? I know winter is very different even from where I am in Manitoba to where my brother is in Alberta.
Do you notice a serious difference in cranking speed? Perhaps Kubota Canada is putting batteries with more cold cranking amps in our Northern machines. I do know those CCA's are super important if you want to have sufficient juice to crank in the winter months.
11,543
We get cold. No ocean warmth for us.
Yes you will get more cranking amps out of a full battery, so yes the tender helps.
I have them on all the equipment that doesn't go into cold storage over the winter.
There are silicone heaters that can stick to a case and heat the hydraulic oil, but most kubota tractors don't have enough of a flat surface on the cases to use them.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,501
707
Richmond, Virginia
Tractor is on a tender most of the time. Both cars are (modern cars have a large parasitic draw), Motorcycles from time to time. Genset kept on a tender.
JasonW
929
633
Al
I would like to point out if you don’t have time to do basic maintenance just plan on working on them when they break down/tear up.
Working full time and with side work on top of a family with small kids takes a lot of time but I manage to maintain all of my equipment plus some for family members. My equipment might not be washed and waxed like some but is always maintained.
Jul 20, 2026
20
17
You're not wrong at all. I struggle to find time, but I do make a point of hitting the high spots, as a quick maintenance job can turn into a long and expen$ive repair in a hurry. My original question, I believe, still stands: are guys finding they get more than 5-8yrs on a decent battery by using this battery tender to keep it topped off at all times? I've seen batteries go even longer that that, but through my basic regime I would be put out to have a battery last less than 5yrs without a good reason.
Jul 20, 2026
20
17
Ok. I wonder though if my battery from factory would have a higher CCA rating than yours in the States? I should check mine when I get home. I see your smallest is a B series, a size up from my BX (Though possibly less HP and smaller engine? Theoretically I'd need more juice for my BX23S than you'd need for your B7100, if I'm reading the specs right)
As for the trans heater, it is a fight. I've got a magnetic heater of questionable value. Long term I hope to see a decent shop in my future. But there are some priorities ahead of that yet, unfortunately.
4,311
Baby backhoe… I posted on this some time ago. “battery tender” is a brand name …as well as a reference…. (Kinda like “xerox” is a brand name as well as a generic term due to common useage)….
The brand “battery tender” is not inexpensive. An excellent, In expensive and reliable counterpart is made by Schumacher and also by Black and Decker (sold on Amazon as well as WalMart) for less than $30. I have several of both brands and use them on more than a half-dozen vehicles around my place, and they Stay “ON” for months at a time, 24/7. I’ve never had a failure and they always keep my vehicle batteries “ready” for work.’
Hope this helps.
11,543
The batteries are the same across the board.
Just because your further north doesn't mean its got a bigger battery.
5,703
I put a "battery tender" on my tractor, and Rhino, and have continually forgotten to plug them in for the past 2 years
The only one I do remember to plug in, is the boats trolling motor batteries, probably because those MUST be plugged in after use.
For some reason I never remember to plug the others in, and as anecdotal as it is, I don't see any real "measurable benefit" to them.
My stuff is in a non-heated garage in Northern Lower Michigan, so its not exactly "warm" in the winter, but obviously it's not the Antarctic either. 🤷‍♂️
I think they are "over-rated", but that's just a personal opinion. 🍻🍻
PHPaul
Apr 2, 2015
1,324
1,672
Downeast Maine
www.eastovershoe.com
Wolfman's comment about freezing is the main reason I use them. I have quick-connect pigtails hanging out of my tractors and the maintainers are on switched outlets so it's just a matter of making the connection and flipping a switch. I do have a suction cup mounted sign on the windshield of the Cabota so I remember to UN-plug it before backing out of the barn...:oops:
William1's comment on standby draw from the electronics on modern cars is also a good point. One reason the Corvette is on a tender while in storage all Winter.
BX23-S,57 A-C D-14,
6,344
'battery tenders' are smart trickle chargers. 'trickle' meaning less than , say 4 amps, of current and 'smart' in that they shutoff ,when battery is charged. They are to be connected on a fully charged battery, as they don't have the power to bring back a dead or low battery overnight. There are 5-7 different styles of battery 'chargers', each is designed for a specific purpose.
If you're in k-k-k-cold country, install a battery warming blanket ! A warm battery is a happy battery , and will supply LOTS of power during starting.
Jul 20, 2026
20
17
Hope this helps.
Thanks for sharing the thread. I believe I'm getting a better understanding now of what the tender is and why some are using it.
Jul 20, 2026
20
17
Thanks for sharing some thoughts from the other side. What sort of temps are you used to seeing? I assume you'd see plenty of snow off the Great Lakes, but perhaps not the same cold?
Jul 20, 2026
20
17
Thanks for your thoughts! And I have to agree, my 2007 Ford Ranger had a battery warmer wired in with the block heater from factory, and man-a-livin', there ain't no weather too cold for that truck to start, even with a weak battery, with both of those plugged in! If the truck had 4x4 it would make for a pretty decent winter rig actually, bombing back and forth to work and such. As it stands, I've learned a few tricks, the principle being never leave home without a good shovel! ;)
5,703
I would say the average day is below freezing, with the occasional negative digits.
We typically start ice fishing in Jan and get up to 2-3 feet of ice before March hits and the thaw begins.
The "Google machine" says our average temps are in the mid 20's during the day, and lows are about 10'ish 🤷‍♂️
Botamon
Mar 26, 2018
504
952
Winnemucca, Nevada
At last count I have something like 13 battery maintainers. EVERY battery in everything I own is constantly on a maintainer/desulfator except for my daily driver.
Unlike the Wolfman's experience, my own is that the battery maintainers nearly double battery life. The tiny battery in my dirt bike used to last only about 3 years. After I started using the battery maintainer now I routinely get at least 6 years out of those batteries. The big Group 27 battery in my ancient John Deere 2020 diesel lasted 13 years once I put it on a maintainer/desulfator. At the price of batteries these days I consider a maintainer a great investment.
Jul 20, 2026
20
17
13 yrs, that is certainly worthy of note! Now I'm wondering what the cost would be owning/operating the maintainer the full 13 yrs versus buying a second battery during that time period. But of course, there's also the difficult-to-calculate cost of having a dead battery (typically on the worst available day) twice instead of once. I may have to try one of these units. Goodness knows I have enough batteries kicking around!
