Battery size question
jd57
L225, kingkutter 4' bushog,A&B 4' boxblade
Dec 14, 2014
38
hilham,tn.
Hi guys, I have a L225 3cyl 24hp diesel. How many CCA battery should I buy?
7,652
I put an 800cca in my l1501. Little smaller then your tractor. But boy she sure glow plugs good and cranks fast :D it's been getting a little sluggish lately but most of that is due to a 30 year old starter thats due for a rebuild.
8,441
Measure the battery tray and go with the norm for that size, you really don't need a huge CCA battery to get the job done.
600 to 800 is norm, go with the higher value if your cold or if it's a hard starter. ;)
Tooljunkie
May 13, 2014
4,150
Thats not saying if you can get 1000 cold cranking amp battery that fits, doesent mean you should. 800 is more than enough, when approacing 1000,plates get thinner so they can fit more. I get more life out of a 750 or 850 than a 1000 cca battery. Sold,tested,installed 1000+batteries.
Been thinking about replacing my battery too, gets really weak when colder, afraid i may smoke the starter if i keep this up.
2458n
129
covington ohio
It is true that a 800 cranking amp battery is able to use heavy plates instead of thin ones tightly packed in the same space. I have a L245DT and use 1 of the batteries out of my 7.3 Ford 350.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
all of my kubota motors get used cat batteries, that are 3 years old, or so. The new batteries go on the vehicles that need to be ultra dependable. I think 210 CCA would start most kubotas, IMHO.:D
CaveCreekRay
Jul 11, 2014
2,631
104
Cave Creek, AZ
I measured my original battery and noted the positive lug location and went to Costco and bought an Interstate that fits in perfectly and has 30% more CCA. OK, I live in AZ but, my barn gets down in the 40's at night. Ten seconds on glow and that piggy starts up right now.
You can never have too many CCAs... Especially in the Great White North...
CaveCreekRay
Jul 11, 2014
2,631
104
Cave Creek, AZ
I swapped the battery back when I was beginning to think it was my starting problem. Nope. :rolleyes:
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I run the exact same Costco battery in my Kubota, F350 Powerstroke, and V10 Excursion. I think it's rated 850/1000 and 100 month warranty for about $100.
