Backhoe L-4530B is there an Updated valve body option out there???
gonzo2850
kubota L2850
Jan 26, 2022
12
conover
Not sure of the year Backhoe, but it came with the tractor which is a 2850. I'm finding out parts for this is becoming scarce. I like my old tractor and I'm not made of money. So, with that being said, I'm open to options, either a new aftermarket updated valve body I can just attach the hydraulic lines to or do I try to find the parts and put bandages on the existing one? If someone out there knows of an updated valve body that can work with it, please share. It be greatly appreciated.
8,700
gonzo2850
kubota L2850
Jan 26, 2022
12
conover
Here is one option, you will need to verify the amount of spools you need and the connections.
Have you used this yourself? I'm not even sure if that backhoe is less than 11gpm. I'm sure it is but not positive.
5,151
Not that paricular valve but many of their other models. The hydraulic pump on your tractor produces 8.7 GPM max.
OOPS - I see that hoe has a dedicated pump - either Cessna or Fenner. If the pump has a dataplate with model number we can lookup the size.
gonzo2850
kubota L2850
Jan 26, 2022
12
conover
Yea it runs off PTO. I'll check next week and get back to you, Thanks
