b9200 with FEL - i need a correct size ballast box
kubotab9200
B9200 & G4200
Feb 22, 2014
southbridge ma
hi
I am looking to make or buy a ballast box for my b9200. What size/weight would be good for this model tractor. My first impression was the heavier the better but now after reading some more information about it i don't want to make it too heavy or too light. Is there a general rule of thumb as to how much weight i should have in the back of the tractor? The tires (as far as i know) are not weighted. I will be "playing" in dirt by moving some significant amounts of it and on some sloped terrain.
Thank you for your input.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
I have a B9200 (I see you have another post out here too I responded to) and I use approx 800lb counterweight. According to the specifications, the tractor is designed to lift a 1000-1200lb weight depending on how far it is out on the arms.
I used a 18"x18"x5' waste concrete block and broke it in half...
kubotab9200
B9200 & G4200
Feb 22, 2014
southbridge ma
Thanks for your reply. I am just curious how did you get the pins into the concrete block?
My plan is to either make a box out of wood and fill it with cement or have someone build me one out of metal and put rocks and stuff in it. I just don't want it to bee too heavy or too light.
Thanks
