B8200HST-DP 4wd
SLV
B82000-HST-DP 4WD
Jan 15, 2024
San Diego
Hi everyone,
I’m trying to help my 82 year old father in law with his B8200. I am searching for an obsolete part #H6780-56000 (bevel gears in the front end). I have called every parts dealer that comes up on an internet search with no luck. Does anyone know of a used parts dealer or where these gears could sourced? Thanks in advance.
6,378
Try sending OTT member @007kubotaguy a message with part number, etc.
I think he has more older L series parts, but worth a shot.
Good luck!
wdlanning
L3750, L4310, B20, Genie Boom
Nov 7, 2016
221
11
philadelphia pa
Hi everyone,
I have the gear and pinion gear for one front axle. Can ship near Philly
MOD EDIT PM email please
SLV
B82000-HST-DP 4WD
Jan 15, 2024
San Diego
Ok, thank you for the reply. I will need to figure out the gears you are referring to and if they are the same.
8,249
The bevel gears are not the same as the ring and pinion.
Try All States, they have several options:
SLV
B82000-HST-DP 4WD
Jan 15, 2024
San Diego
Thank you, I have. They have one for a B9200 but not a B8200. I have been given conflicting answers as to whether they are compatible. Maybe someone could answer that question.
8,249
The B9200 shares a lot of the same parts in the front axle but that gear is not one of them.
8,249
Great this helps my search.
Sorry reread, I had to edit, I was looking at the wrong gear set
They are not the same on those bevel gears.
And on the B8200DT only some cross over, there was 2 gear sets made for those.
SLV
B82000-HST-DP 4WD
Jan 15, 2024
San Diego
Thanks again, I appreciate your input. I will keep hunting. Hopefully something will come up.
3,329
Wolfman you are Amazing! We’re all damn lucky you run this place!
