B8200 voltage regulator
Garvas
Kubota B8200
Oct 27, 2013
Benbrook, Texas U.S.A.
Where is the voltage regulator located on a B8200? Spent the better part of an hour looking and it must be located behind the fuel tank on the back of the dash. Right? I am assuming you need to move the fire wall and fuel tank to replace it. The tractor is in the country about 15 miles from my house so I need to see which one it is to replace it. The Dynamo is not charging the battery and I feel sure this is the problem.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
If it is indeed under the dash like its located on my B6100 I had to pull the steering wheel and remove the dash to gain easier access to the volt reg to replace it. May want to look into taking a gear puller with you to pop the steering wheel off.
