B8200 hydroduilic question
jmjbrtw
Nov 17, 2013
Williamstown
My B8200 which i bought used this summer has a small fluid leak on right side at one of the hose connections.
I believe the fluid is low because bucket will not work. It clicks and tries but nothing happens
The reserve under seat level is good. Is there another for bucket system.
It worked great all summer and yesterday nothing, after sitting since September the last time i used it
Help
9,981
Is it a factory loader, Kubota brand?
Are the loader hydraulics connected to the factory tractor hydraulics?
Is the three point working?
jmjbrtw
Nov 17, 2013
Williamstown
Nothing on Hydro system working.
I took the side cover off and the connection fitting that attaches hydro line to the engine is cracked and leaking fluid when i try to move bucket
9,981
Looks like a suction line, that should be an easy fix, just pop it off and braze the crack in the fitting and you'll be back in business, oh and when you pull the line make sure you have a catch pan, it will probably leak out a lot of fluid.
jmjbrtw
Nov 17, 2013
Williamstown
Part 2
The Hydraulic line(discharge) that comes off the bottom of pump was leaking and I had it brazed, new o-rings, and no more leaks there.
I pulled the Hydraulic fluid filter at bottom of transmission and cleaned it.
Is cleaning good enough?
I drained the fluid and put it back in. It was about 3.5 gallons. The dipstick is 1/4. How much fluid should it have?
Still the Hydraulic system is not working. zip-nothing
Help, I need some other ideas on what it could be
paco mazo
4350 diesel
Nov 22, 2013
wallkill,ny usa
Re:4350 kubota
My brother unknowing filled the hydraulic oil reserviuor to the point that when I drive the machine, it overflows (out of the plug in front of the seat, looking down between your legs). Should I drain off some of the oil? I was thinking of getting a turkey baster and drawing some out as it's real cold here and it seems the easiet way to get it out without getting out the tools etc to get to the drain plug.. Will it damage anything if I run it this way other than getting oil all over the place?
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
Re: 4350 kubota
cleaning my screen didn't totally work on mine , a new screen made it work like it was supposed too. But even with a dirty screen it still worked it was just slow.
