B8200 3 point hitch question
twiggly49
B 6000 KX 91-2 B8200
Jan 3, 2022
murrysville pa
I recently purchased a B8200.I changed all the fluids when I got it,along with cleaning or replacing filters.Yesterday when I raised the 3 point hitch it responded slowly and jerked coming up.Fluid level is fine.I took the lift arms off and the top link in case something was binding but no improvement.Ideas? Thanks
5,242
I would guess your pump is not delivering a good solid oil flow. Is this new?
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
You said you cleaned the filters. Did this include the hydraulics strainer ?
hodge
Nov 19, 2010
2,950
514
Love, VA
You could have air in the system, which hasn't purged yet. Raise and lower it a number of times, and see if it improves.
5,242
No.It has 850 hours on it.Any way to be sure it's the pump? Thanks
Careful - I did not say it was the pump - just a problem with oil delivery. Could be a clogged strainer starving the pump or a vacuum leak in the line from when you had it apart.
