B7510 Won't Move
TheGolfTech
Kubota B7510, John Deere 1070, John Deere 4700, John Deere 4120
May 22, 2018
Eugene, Oregon
We have a B7510 that we use at our golf course for picking range balls. It will not go forwards or backwards. It makes no noise whatsoever when depressing the HST pedal. All linkages are intact and operational. This tractor is used by teenagers so someone cut off the PTO and H-N-L levers to make it more simple to operate (not happy about this). I am going to replace the filter but I don't have any hope that this is going to work. It definitely seems like the tractor is in neutral, either between two and four wheel drive or between high and low gears. Now I don't know what lever is for high low and which is for the PTO. The fluid level is good, and it is nice and clean. Any ideas would be much appreciated.
9,153
Range is the inboard lever, PTO is the outboard lever.
Try the range lever first, that would be the most likely to have kicked it in neutral.
Then if that doesn't do anything, with it running turn on the PTO if it doesn't spin too, it's got an issue like the clutch has went out.
TheGolfTech
May 22, 2018
Eugene, Oregon
So I found the problem. The splines on the input shaft are gone causing it to not spin whatsoever. I don't have a repair manual, is it going to be difficult to do without one?
