B7510 fuel system
bulletman
B7510 hst
Jul 10, 2016
South Mills N C
Ive had my B7510 since 2005, purchased new,,,, 579 hrs on tractor,,,, all maintence has been done,,,, fuel dropped to 1/2 tank lost rpm, rpm slowly climbed back up then dropps off,,,,, chgd fuel filter no luck,,, filled fuel tank up no problem ran fine,,, 1/2 tank dropped rpms again. drained some fuel out of tank ran fine,,, seems problem only exsists at 1/2 tank, fuel cap and air filter new??????????
7,655
fuel ststem
Sounds like a fuel pump issue. As long as the tank is over 1/2 full it's gravity feeding. Once below half full, the pump is having to pick up the slack.
Fuel pump could be weak, or if it's electric, it may have lost power do to blown fuse, corroded connection, ect...... Or could have gave up the ghost and quit working all together.
Could also be trash in the fuel tank as well.
Fredbussiere
B7510HSD
May 28, 2016
22
Barrington,NH
I'm having same hesitations, but not seeming to be related to fuel level with my B7510. Was going to change fuel filter today. Never has been done at 250 hours.
Any ideas out there?
8,444
bulletman,
Sounds like fuel pump, but I would check the filter too while your at it.
Fredbussiere,
If the filter has not been changed in 250 hours I'll bet it's plugged right up!
mendonsy
B7500HST/LA302
May 28, 2012
357
34
Mendon, NY
My B7500 has a small "lift pump" mounted next to the high pressure fuel pump. If your B7510 is the same then that would be a good possibility to cause your problem..
bulletman
B7510 hst
Jul 10, 2016
South Mills N C
Ok guys thanks to all for input,,,, Now drained tank empty, clean as a whistle inside, blew air back through line , chkd tank again still clean, put back together bled injector lines, ran good bout 3hrs,,,, doing same thing but this time i noticed fuel dropping below the filter element, then slowly refills runs good then drops off again?
mendonsy
B7500HST/LA302
May 28, 2012
357
34
Mendon, NY
Hmmmm ..... I'm about out of ideas!!
My B7500 has a check valve (or something) built into the fuel filter housing that stops the flow so that you can change the fuel filter without draining the fuel tank. If your B7510 has the same setup maybe that valve is not working right? I'm not sure why fuel level would have any effect on that, but something has to be keeping the fuel from getting to the filter.
