B7510 creeping forward when idling
Wyflyer
B7300
Nov 6, 2015
Uvalde, tx,usa
I recently bought this B7510 as a fixer upper project. It has 425 hrs. I fixed injectors, got it running and sorted out. Now have one last issue....
With it idling and feet off the pedals it creeps forward at turtle speed. I've looked over the forward/reverse linkages and it appears any adjustment or alignment hardware is behind the gray steel support frame around the transmission.
Anyone know how this works and where the adjustment is located? And can it be serviced without removing the floors and framework?
thanks
7,186
There's a variety of reasons the pedal won't center, and some of the issues are specific to certain models. Usually it's a matter of the damper, linkage lubrication, or something bent.
Given your tractor was bought as a "fixer upper", I'm guessing something just isn't working freely to return the pedal to center. My first thought would be the damper, but there can be other issues.
Try www.kubotabooks.com for a workshop manual (WSM).
Go to https://apps.kubotausa.com/illustrated-parts/ . Agree to legal, put in your B7510 model, OPEN the book for your model, then SPEED CHANGE, then SPEED CONTROL PEDAL. Will show a parts diagram of the linkage.
An HST "creep" comes up regularly for several models. These threads from OTT might give you some ideas:
https://www.orangetractortalks.com/forums/showthread.php?t=36221&highlight=damper
https://www.orangetractortalks.com/forums/showthread.php?t=35970
https://www.orangetractortalks.com/forums/showthread.php?t=29513
Wyflyer
B7300
Nov 6, 2015
Uvalde, tx,usa
I was able to look at the correct diagram and see how it works and make the adjustment. Thanks for the guidance. There is an eccentric bushing which changed the engagement of the rocker cam which centers it in the correct position.
After I learned how it works from the diagram it was a simple 10 minute adjustment using a 12mm socket and a flat screwdriver.
thanks
