B7510 3 pt lift
3,117
Use some penetrating spray and spray the area where the round rod comes into the tractor case. Spray the area where there are washers and nut holding the lever to the rod into the tractor with a lubricant.
I would assume that area is corroded but did this problem come up suddenly or over time? If it was suddenly then probably a bad assumption on my part.
11,152
Very commonly the bind is actually in the pivot point on the feedback linkage, normally where the rod connects to the three point lift arms.
Clyde Smith
Kubota B7510 LA302 LOADER
Apr 30, 2024
20
Jacksonville Florida
It is my father in laws tractor and it has been like this since I started working on it .
I have got everything working but the rear lift so far.
It acts like it's jambed some how.
