b7500 wheels
Lee Hilbert
B7500
May 1, 2024
Hampton NJ
Hey guys, I am needing to replace my b7500 (31x15.5 15) rear rims because they are rotting. My local dealer says they are not available. Any suggestions? BTW I want to go turf tires. After market wheels? rebuild the wheels? Go up or down in size to be able to find wheels(front and rear)?
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
181
Attalla Alabama
mossycreekoutdoors.com
Bkt makes one that's reasonably priced. I found other true turf tires also but they are pricey. If you change the rear size you'll have to change the front also to keep the ratio correct for 4wd.
rut3556
TG1860
Oct 23, 2015
114
17
NH, USA
I had the same issue with my L2250 and ended up having new rears fabricated by Wold Rim out in Iowa. They weren't cheap but they're much beefier than the originals.
Shadetree605
kubota b2100
May 1, 2022
228
114
north little rock, ar
don't know if you ever solved your tire/rim issue ?, but i still have the factory turf tires/rims i took off my b2100. they still hold air front and back, rims are in great shape from what i last seen when i removed them ?, i will never use them, put them in my shed out of the weather, if you are interested in taking them off my hands ?, i'll let them go pretty cheap, but i won't ship..lol.
Rsutton22
Kubota B7500 HSD
Aug 19, 2024
Coatesville,IN
Hello, I have a B7500 with 31x15.5-15 rear wheels that have rusted into dust. So if you still have yours how much do you want for them? And where are you located? I only need the rims though…
Lee Hilbert
B7500
May 1, 2024
Hampton NJ
thanks for responding, are they the size I need?
