J jdefouw231 New member Equipment All Jan 31, 2019 1 0 0 Conklin Jan 31, 2019 #1 Looking at some used B7500 tires, will they fit on B7200
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 32,975 8,415 113 Sandpoint, ID Jan 31, 2019 #2 The ratio is slightly off, should be 7-12 fronts not 6-12. And I don't think they use the same bolt pattern, but could be wrong on that, you would have to measure and compare.
