B7500 3pt rear not working
zieg85
B7500 B3200
Jun 30, 2026
Brighton, IL
I just installed hydraulics for a front plow. I bought the correct parts from Messick's and got that all working fine. The hydraulic fluid is full according to the dipstick. All seems to be working as it should except my 3 pt. Is there a bleeding procedure to try? It all worked fine before I removed the deck. I am at a loss. I don't have a manual for the tractor, purchased it used about 7 years ago. Thanks in advance
11,389
How did you attach the hydraulics for the blade?
Pictures of connections would really help.
7,409
You dont need to bleed anything. - you have plumbed something incorrectly.
My crystal ball says you reversed the tank and power beyond connections on your new auxiliary valve.
zieg85
B7500 B3200
Jun 30, 2026
Brighton, IL
Bingo, you were right!!! I hadn't looked at it closely enough. I had 2 lines reversed. Thanks so much!!!
