While I have the steering column and shaft out (replacing the lower bearing and upper grommet as well as cleaning everything up) I thought I would check the oil in the steering box.
It's fairly clean, good sign, but I realize I have no way to know if it has an adequate amount of oil. According to my WSM the capacity of the box is .21 quarts. Not much. Yet the oil level is down from the check plug on top by two inches.
Kubota has a special oil or I can use SAE 80 or 90 the manual says.
Any idea of approximately how full the box should be?
I don't have time at the moment to drain the box and refill it.
Thanks for any help,
Roll
Roll
