D darve5 New member Equipment ZL1801DT, B7300, CIH 275 FWD and several implements May 10, 2009 12 0 0 friendswood tx. Aug 2, 2015 #1 To remove the idle shaft on the mid-pto do you have to open the transmission case, or can it be done by removing the mid-pto case?
S Shadow New member May 18, 2015 190 2 0 Somewhere Aug 2, 2015 #2 Only thing you can access by taking off the mid pto case is the PTO shaft, and the shift gear. If the drive gear off the transmission is damaged, you'll have to get into the transmission.
D darve5 New member Equipment ZL1801DT, B7300, CIH 275 FWD and several implements May 10, 2009 12 0 0 friendswood tx. Aug 3, 2015 #3 Thanks for the information, I thought would be the way to repair it, just hoping.
