B7200D
MartinY
Kubota B7200D & BX2200
Jul 23, 2014
Bedford,UK
Hi can anyone tell me the maximum weight that can be lifted on the 3 point links on a B7200D?
3,006
rear lift at ends
1,036 lbs [469 kg]
Rear lift (at 24"/610mm)
705 lbs [319 kg
MartinY
Jul 23, 2014
Bedford,UK
rear lift at ends
1,036 lbs [469 kg]
705 lbs [319 kg
Thanks for your help.
I hoped to use a smallish post driver and that lift sounds sufficient. My only other concern is when I tip a trailer with a single acting ram and then lower it it comes down quite slowly. Will this work for the ram on a post driver when the weight has to be dropped fast?
Thanks hopefully.
N3BP
Sep 20, 2016
509
238
Lebanon, PA
Having the exact same machine, I can tell you that it has enough lift to easily bring the front end off the ground, even with a 60LB winch hanging off the front end.
