b7200 PTO seal replacement
CJN8
B2650HSD, LA534 FEL, Gearmore Box Blade, Bush Hog, Cimmeron Rake
Nov 16, 2013
122
San Diego, CA
I am going to replace the PTO seal on my tractor. I have a question regarding the PTO rear cover. Does the PTO rear plate require a paper gasket or will ultra black RTV sealant work in its place? I can make a paper gasket to fit the plate but I think the RTV may seal better. Thoughts?
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
I have checked the parts manual and there is no paper type seal shown.
We could conclude that a paper seal is not necessary.
About one year ago I had minor leaks around that area and I replaced the PTO shaft oil seal also cut a paper seal for the PTO plate and installed it with gasket compound on both sides.
No more leaks.
Your call on what to do!!!
Good luck.
