b7200 pto clutch not working
Dana
b7200
Nov 2, 2010
20
sydenham, ontario canada
I have just go my b7200 hydro, back togeather after replacing the head, clutch, preasure plate, throw out bearing and machining for pilot bearing. The good news is the motor runs great, but the clutch does not seem to be working. I was hoping that someone would point me in the right direction.
Oh Ya I just wanted to say this site is great.
Thanks to everyone for their imput.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,190
171
Hardisty, Alberta
The most common reason that I have seen for a new clutch not releasing
is that the clutch disc is installed backwards binding against the flywheel.
Ed
ipz2222
L235, bx2670
May 30, 2009
1,927
34
38
chickamauga ga usa
In your header you say pto clutch not working, then you say clutch is not working. Clarify. Is the clutch not releasing or not engageing????
Dana
b7200
Nov 2, 2010
20
I took advantage of this nice fall sat and worked on my tactor, I found that it was a linkage adjustment that had to be made. Not as big of a problem as i thought.
Thanks to everyone who helped!
hodge
Nov 19, 2010
2,963
531
Love, VA
Glad you figured it out, and didn't have to redo any of your work. Simple solutions are true blessings!
