B7200 Oil Pressure
sdcassel
B7200HD 4WD, B1640
Jun 15, 2009
35
Edmond, OK
I have been chasing down the cause of low oil pressure on my 1986 B7200 HST 4WD.
I've changed the sending unit, pulled the timing cover to inspect the front cam plug (it was intact), replaced the oil pump and oil pressure relief valve, but still have only about 12 psi (at idle) and 24 psi (at 2500 rpm) when cold, but it drops to about 4 psi (at idle) and 10 psi (at 2500 rpm) when warm.
I don't have the know-how to get to the rear cam plug, and the local Kubota service guy says there is only one on the front anyway (although the parts manual shows one on each end). He says an engine overhaul is the only option. The engine runs and sounds fine to me, but he says it's noisy when throttling back down, indicating mechanical wear. Should I insist he check the rear cam plug, since if that's missing an overhaul might not be necessary?
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Welcome to the (low oil pressure club). See "low oil pressure L235".
I can't answer your question for sure but, every eng I know of the rear cam plug is in the back of the case where the bell houseing goes. A leak there will put a lot of oil on the ground, not low oil pressure. Unless it is blown completly out, then a lot of oil on the ground and lower oil pressure.
sdcassel
B7200HD 4WD, B1640
Jun 15, 2009
35
Edmond, OK
So are worn bearings the only other reason for low oil pressure?
What if I do nothing and run with the marginal oil pressure? What more damage can it do?
sdcassel
B7200HD 4WD, B1640
Jun 15, 2009
35
Edmond, OK
Thanks; I had completed all of those except the bearing clearances. My Kubota mechanic says it will cost big bucks to tear down and check all clearances; he doesn't think it is worth it!
sdcassel
B7200HD 4WD, B1640
Jun 15, 2009
35
Edmond, OK
The mechanic also thinks he's hearing piston slap, so the cylinders may have to be bored and oversized pistons installed.
