b7200 mowing deck rc 60 72
zazzo
b7200
Jun 15, 2018
11
amesbury
been seaching a deck for b7200 (rc 60-72) with no luck, however i did find one for b7100 (rc 60-71) will it fit b7200
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Zazzo, are you looking for the entire set-up with the front mechanical PTO and deck or just the deck?
Also, what state are you located, not familiar with the town.
Jeff
zazzo
b7200
Jun 15, 2018
11
amesbury
was hoping to find hydro model deck so i could run from mid pto. any option is better then none . im in Mass. north shore
9,749
I'm pretty sure that, again like before, a non hydro deck will not work on a hydro, dimensions of mounts are different.
If jeff posts a model number I can confirm my suspicion. ;)
9,749
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
The RC60-72 deck was used on the Gear driven B7200E (Two wheel drive). It was driven with the front mechanical PTO and a drive shaft back to the gearbox. The deck looks like the same one used on the hydro except for the gearbox turned 180 deg. I am not 100% this is the only difference. Jeff.
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
From the Kubota Illustrated parts list the B7200HST uses the RC60-72H mid mower deck. It is not the same as the RC60-72 gear drive tractor decks. There are more changes as the -72 gearbox is offset the the right and not directly connected to the center spindle. Hope that made since. Jeff
tealetm
B7200 and B2601
Apr 20, 2015
46
Upstate, NY
I can confirm that the rc60-72 used on a b7200d is not the same as the rc60-72h needed on the b7200hst.
I’ve had both and they are different. I’m parting with my b7200hst but I’ll have to keep its mower deck with the tractor. I’ve only seen one or two decks come up for sale in the last few years.
