B7100D 4WD transmission fill level
BirdTRD
B7100
Nov 24, 2016
White Marsh, Maryland, USA
Hi all, How "full" should the transmission fluid be? I removed the cap and see fluid about 1/2 way covering the gears in there. Should the level be all the way to the top or do I need to drain it an put a specified amount back in?
Thanks
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
There is a little black dipstick, in close proximity to the cap on the top of the transmission.
BirdTRD
B7100
Nov 24, 2016
Thank you. I saw that but thought it was a breather cap.
Another question. I found the 3 sets of drain and fill plugs up front (wheels and diff) but for the rear diff, does that share fluid with the trans? I can't seem to find anything back there that looks like drain or fill.
Thanks
8,603
Thanks
Do you have the WSM (aka service manual) for it?
BirdTRD
B7100
Nov 24, 2016
Yes, I do have the WSM (422 page Workshop manual) but it is more of a disassembly/rebuild procedure manual. I found some references to drain plugs in there but nothing about fill plugs or capacities or fluid types to use.
I was able to find a B7100 Owner's manual in PDF that was far more helpful than the WSM for this. (pgs 19-20).
I guess this falls under RTFM... or better yet, Read the "right" Freakin' Manual! :p
