B7100
Bobsbait
B7100
Jul 20, 2022
19
I replaced glow plugs tried to start something arched under dash xill not turn over any ideals
8,283
Only seen 2 fuses where would main fuse b located ck voltage to starter had 8 volts
There is no main fuse on a b7100, I don't even think there is a fuse link on that model.
If there is it will be on the hot wire that runs from the starter to the dash down by the starter.
If you've only have 8 volt's you have a battery or battery cable issue.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
370
139
Attalla Alabama
mossycreekoutdoors.com
Old style 7100 had 2 inline fuses under dash new style hst has 3. But neither of those would only give you 8 volts at starter in any scenario. Does you oil temp light still come on? Does your glow plug controller still work?
