B7100 will not stop
sro451
b7100
Apr 16, 2012
Palm City Fl.
Good morning, I have a mid 1970's b7100. When i push the clutch in and brakes it stops. However when the brush hog is running on the 3 point hitch I push the clutch and brakes it will not stop it takes approximately 15-20 feet to stop, Unless I pop it out of gear. Very dangerous going down hill. Any answers on how to fix the problem? Thanks Bob.
Piker
2012 Kubota 2320, 2002 Honda Rubicon
Dec 1, 2010
164
Riverview, NB, Canada
You need an Over Running Clutch (ORC) on your PTO shaft to prevent the rotating mass of the bush hog blades from applying power through the shaft (before they spin to a stop) & driving the tractor ahead. My 1980 B7100 appears to have a built-in ORC (near as I can tell since I don't have a 3 point mower) as it only rotates in one direction when turned by hand with trans. in Neutral & PTO disengaged. Can't find any mention of it in either of the manuals I have for the tractor.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Yep, everything Piker said. When trying to stop with the PTo engaged your brakes have to dissipate the energy stored in the momentum of the tractor (as usual) and the rotational momentum of whatever implement is attached. The way the PTO shaft is plumbed through these transmissions the implement acts like a second engine attached at the other end of the transmission driving the wheels. The clutch only allows power to flow out of the pto shaft, not back in preventing it from driving the wheels. They're fairly inexpensive but they add length to the PTO shaft so you'll probably need a slightly shorter shaft. Make sure you get the right sizes.
hodge
Nov 19, 2010
2,948
513
Love, VA
Tractor supply carries them. It is a common issue- most older tractors are designed that way, and need an overrun clutch. You have to be REAL CAREFUL without one- the force can push you into places that you don't want to go!
My later model 7100 must have an internal one- when I disengage the pto on mine, I can hear an internal clicking as it stops revolving.
http://tsc.tractorsupply.com/search...icUrl=http://www.tractorsupply.com/-027114899
I don't know if this is the size you need- just showing what it is.
sro451
b7100
Apr 16, 2012
Palm City Fl.
Thanks guys that helps. I bought this tractor from my boss, it came with the brush hog, rake and scraper blade for $1000.00 he said he coulded get it stopped and had no use for it. His lost my gain. Thanks again i should beable to fix it for looks like under $100.00 Bob Kohl.
hodge
Nov 19, 2010
2,948
513
Love, VA
Wow- you got a great deal!
Stumpy
L175
Dec 1, 2011
848
NE Ohio
$1000? Wow you lucky..... I'll trade ya for my L175! Low hours! I promise I ran before I took it apart :D
Sounds like he got scared of the machine and just wanted to get rid of it rather than do a little bit of research or ask for help. His loss.
Piker
Dec 1, 2010
164
Hodge, thanks for the confirmation regarding the internal ORC. I guess prior to 1980 they didn't have one, but from what I can tell mine has one. Also, just got a Bush Hog 48" 3 point finish mower since I first posted this morning - $200, from my buddy I bought the tractor from 1.5 yrs. ago. He's delivering it tomorrow & may exchange it for the labour to mill parts for 14 cabinet doors. He's also considering selling me his 48" Bush Hog bush hog (?). Don't have a lot of use for either but can't pass up a deal.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
My 1978 B7100's got an ORC,I wonder if a mod was done at a later date?
Dave
Edit: just re read my post and noticed its my 300th post,cor i must have been here some time!!
Stumpy
L175
Dec 1, 2011
848
NE Ohio
If it's internal unlikely, it's probably a production change. Adding an internal overrunning clutch to a transmission not designed for one would require a very skilled and very bored machinist.
Kytim
Aug 14, 2009
848
15
Western Ky
my '77 model b7100 does not have an Internal ORC. would be interesting to know where the change break is in regard to serial number.
3,071
My 1980 B7100DT (serial #B7001-67625) has the internal ORC.
B7100
Feb 11, 2010
422
Wales
My B7100 serial no: 52661 and has internal ORC, 1978??
smud6ie
