I recently became the rather proud new owner of a Kubota B7100HSE. Although this is just the 2wd version I must say this thing is built like a tank and I really like this tractor.
Next let me say what a great and valuable website you all have here, I cant believe the luck I have had over the weekend. One being getting my first Kubota and Second finding this site.
With that out of the way, I now have my first question. My tractor for the most part is in very good condition, however it is getting a few years on it and like all of us it does and will need some item reworked or repaired. I have no problem in doing either and really look forward to learning more about our new little friend.
My first question pertains to the forward/reverse pedal on the right side of the tractor. On my particular tractor this pedal seems to be very touchy but not by being loose (loose would be an Improvement) Its to tight. I have had other tractors that have had the foot controls but never one that was like this.
What happens is: say you are going forward and need to slow down or plan to reverse is that it takes a lot of force to move the pedal, in trying to slow down or find the neutral position it will about throw you off the tractor. I end up using the clutch right now to stop it of course.
It may be set up this way from the factory but just seems like it should move easier.
Is there a detent for neutral?
In operating the tractor does one just use the forward/reverse pedal as it would imply?
Right now If I need to slow down or reverse I use the clutch and once stopped I move the foot pedal.
I hope I have explained my problem here, I can get myself confused at times so I may have to give more details.
I need to get the service manuals ordered so I can see what does what on this tractor.
I would like to thank everyone in advance for any ideals or input as to the issue I am currently having.
Thanks again
Greg In Kentucky
Thanks again
Greg In Kentucky
