B7100 gear driven - pto hard to engage- gear chatter
Mrmud73
Pittsburgh, Pennsylvania
On my B7100 the PTO has a difficult time engaging in 2nd gear and will not engage at all in 3rd.
Everything works fine in 1st, but has trouble engaging in 2nd followed by a chatter.
Any suggestion on where to start to begin diagnosing this issue would be much appreciated.
Thanks
twomany
B7200
Jul 10, 2017
793
138
Vermont
It could be as simple as lubrication of the shift shaft and linkage.
It's not like you can count on splash lubrication.
3,095
If your clutch is not fully disengaging it will cause the symptoms you describe. Does the transmission grind also?
8,757
Sounds like you are in store for a transmission tear down, I'm going to say your most likely candidate is a failed bearing in the PTO main shaft.
Mrmud73
That’s not the answer I was looking for but I feel we are in the right ballpark. How do I further diagnose the problem, where do I start and how much of the tractor has to come apart? Do you know if any videos or diagrams to help me along?
Thanks!
8,757
Go to Kubotabooks.com and download the three part WSM (service manual).
On that model splitting it at the motor and working back is the easiest.
Most parts are light enough to be able to easily handle, never force anything to come apart as Kubota's are tolerance fit parts , Parts never pressed into a housing.
