B7100 - fuel issue
521
Sold the '94 B7100 HST, bought a 1987 L2250 w/ FEL
Jan 30, 2014
40
Owings, MD
Working, forgot to check fuel. Engine just kinda died - didt sputter - just kinda faded to off.
I filled the tank - tried to restart. Gurgled a few times but didnt start.
I bled the fuel line of air and noticed no fuel dripping from bleed bolt
Does this thing have a fuel pump?
Its cold out but not cold enough for fuel to gel.
Thoughts?
bmblank
Mar 4, 2015
626
271
Cadillac, MI
I don't believe it has a fuel pump. I would imagine it'll take quite a bit of turning after running it out of fuel (even bleeding the lines properly) to start up. Plug it into a battery charger and see if it'll go. Luckily I have yet to run mine dry.
I'm sure NIW, among others, will know exactly what's going on and can give you specifics.
CountryBumkin
Sep 27, 2015
568
Central FL
Jan 30, 2014
40
Owings, MD
Thanks all!!! My "process" for priming was a bit off. Took a little while longer then expected and i now smell like i bathed in diesel but the old gal is running.
Got firewood to haul and need to unload new rear blade. Glad to get her running again!
