B7100 Battery and front tire questions
Camtender
Kubota
Jun 30, 2020
Oregon
I recently acquired a B7100 with no battery in it, I got a new battery, but cannot install it as there is no positive/negative indication on the cables, they are both black? Any way to know the negative side???
Also, need new front tires, I am not planning on going with fluid in them, any tire suggestions, should I go tubeless as I am having the wheels blasted and painted to remove all paint and rust.
Thank you, View attachment 60894
2,831
Get a 51R battery (your cables make not be long enough to reach without the "R"
And pos side will go to the starter and the neg will go to the engine/frame.
Is the B7100 4 wheel drive? or 2wd?
