B7001e Just refuses to start !
Little Roudy
Kubota B7001e
Jun 2, 2021
Australia
Got ourselves a little orange tractor. Guy we bought it from told us, "It is hard to start" .... Not wrong - It will not start!
He said he has just had the injectors replaced. We pulled out the glow plugs and found one perished, so have replaced all 3 with new ones... Still won't start.
Turns over, winds up, puffs smoke, really tries to start, I mean tries its' heart out to start, but just can't....
We really want our "Little Roudy Tractor" up and running.
Can anyone point us in the right direction? Please Help....😢
whitetiger
Nov 20, 2011
3,747
2,162
Kansas City, KS
With a voltmeter or test light, see if you are getting current to the glow plugs when the switch is turned to the glow position.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
583
337
Mandeville Louisiana
+1 on the compression test and confirming the operation of the glow plugs. When you say "fuel is also getting through" Do you mean the entire fuel circuit, from tank to the top of the injectors?
shootem604
Apr 23, 2018
874
British Columbia
X2. Loosen the lines and crank over to ensure fuel is getting to each injector.
Jim L.
886
181
You may already know this: do not let some drongo talk you into using starter fluid! This engine will not handle it and likely to cause engine damage.
Cylinder compression test will tell if that is a problem. Fuel is the second. Third is heat; both from compression and glow plugs. And assumes that air is getting to cylinders at right time.
4,228
Yes....NO STARTER FLUID OR ETHER!
However, your wifes’ hair dryer pointed continuously into the intake during the start attempt may encourage it....
You wrote “it puffs smoke”... What COLOR smoke?
Little Roudy
Kubota B7001e
Jun 2, 2021
Australia
@shootem604
First thing we did was replace the fuel to ensure it was fresh and checked that it was getting to the injectors. Happy to report that this is all AOK 😊
@Jim L. & @GeoHorn
Thanks for the heads up on the starter fluid.... Definitely do not want to do any more damage.
It is pretty warm here in Queensland, Australia. 😎☀ Not sure if we need to warm it up any more than what the glow plug is doing?/
Will take a video to give some more information for your other questions.....
Am yet to do a compression test due to no time at present 😔
Little Roudy
Kubota B7001e
Jun 2, 2021
Australia
Well........ Did a compression test and not good news 🥴
1 chamber is reading 250 psi
2 chambers reading 0 psi (Yes, that is a zero) 😳😳🤬🤬
Looks like the poor little tractor needs more work than we were hoping for 🥺
Unless any of you smart people have other ideas as to why this would happen.
whitetiger
Nov 20, 2011
3,747
2,162
Kansas City, KS
Remove your rocker cover and see if you don't have a problem there. Could be someone has incorrectly adjusted the valve lash, have bent pushrods, or a broken rocker shaft.
If the 2 cylinders with no compression are next to each other, there is also a strong possibility that you have a failed cylinder head gasket.
Little Roudy
Kubota B7001e
Jun 2, 2021
Australia
Thanks @whitetiger 😀 Looks like we have a blown head gasket!
We are now on the hunt for a gasket kit. If we are going to replace one, may as well do them all. They all look a bit dodgy anyway. Think the guy we bought it off liked to tinker but not in the good way, just to get him by way. 🤪
Jim L.
886
181
Maybe a good idea to wet test the cylinder with 250 psi. (Small amount of oil.) If the pressure increases, then there may be ring problems also.
As white tiger suggests, best to check valve lash before tearing apart.
