Hi there,
New to forum...just bought a b7001 grey import and l have a few questions regarding the function of the 3 point hitch.
The hitch seems to work very well...but l had noticed that it goes down by its self a small amount after much driving around (on rough roads with load)...not a lot but something l noticed.
Took a look around and found a small leak at the front engine pump for the hydraulics system on the lower connecting pipe (see pic)...figure this is a copper washer that need replacing. Would this be the reason the hitch slips?? Any pointers on replacing these washers would be a great help too.
I was told by dealer not a big issue to replace...might lose a little oil but should be straight forward...
Also l also want to clarify the function of the 3 point hitch....read all the manuals ect and still finding it hard to understand.
My big question is...is it normal that the 3 point hitch can be "lifted" manually (engine on or off)...l can do this with not much force....is that normal??...l was under the impression that the arms would "lock" up or down no matter were the 3 point hitch is set??? Hope this makes sense...l am very new to this tractor stuff....ok any help would be greatly appreciated....thanks guys
cheers farmer jack!
cheers farmer jack!
