B7001-20612 Serial Nunmber
240
B7001
Jan 8, 2022
BC
I have a B7001 SN 20612 that requires a front diff assembly. I have parts manuals for the the B7100. My question is I have two manuals one for old (B7100 SN <20024) and new (B7100 SN >20025). Does any one know if mine would be an old or new style as the diff case part numbers are slightly different.
also refers to old sn <60163 and new sn >60164?
3,037
Welcome to the forum,
Are you sure you have a B7001? Many people see the serial number and it says B7001-xxxxxx
yet it really is an early model B7100
Does it have 4 bolt front rims? If it does it will be the "old style" ........... now the real difference will be the tires on the front..... a true B7001 has these tires:
No code has to be inserted here.
where as the B7100 has these:
the internal gearing is different too!!! SO some parts do not interchange inside - most parts will work on the outside however.
Take a couple of pictures - one of the dash panel too!
240
B7001
Jan 8, 2022
BC
Thank you. The decal on the machine says B7001
Dash is all in asian
Front wheels 4 bolt 5-12
Rears 8-16
believe what they call rice paddy tires but tires made in usa
I have a broken ring gear and diff case
3,037
based on ALL that great info ........... no doubt ...you do have a B7001!
Finding your parts may be harder yet to find unfortunately.
