B6100e engine oil drain plug "gasket"
drbenway
B6100
May 9, 2012
12
New York
Greetings, again :)
removed the engine oil drain plug to find the PO had not used a gasket [as described in the parts book].
however, there was no oil leak at all
what kind of "gasket" should be there-- I have about the right size metal crush washer, but its described as a "gasket" :confused:
any advice much appreciated
thanks!
asbug
B7001 - looks orange to me... Woods 5' scrape, 42" rotary cutter, shreader/chip.
Feb 11, 2011
155
Varnell,GA - USA
Look Reallly good at the plug.
On the old Aircooled VW's I deal with I got one that looked like there was no gasket, the thing didnn't leak (at that spot) and I thought it was odd w/o the gasket.
I looked at it really carefully and noted the the PO had used an aluminum gasket that had deformed perfectly to look like part of the bolt.
Just look really carefully at the bolt, Otherwise I'd install a copper crush washer.
KC
hodge
Nov 19, 2010
2,959
535
Love, VA
I have bought replacement plastic gaskets for oil drain plugs (they come in an assortment package) at Advance Auto. I would imagine that would work for you.
drbenway
B6100
May 9, 2012
12
New York
thanks all, for the replies
checked the plug and pan, couldnt see a crush washer
edit; following up
got the oem parts today-- its a copper crush washer
