B6100 won't start
Tmar04
Mowing
Aug 28, 2013
81
Eastman Georgia
Does b6100 have a lift pump? Or does injector pump depend on gravity to feed it ? Engine tries to start, but when u release key, it dies. Just a thought. Fuel and fuel filter clean . Thanks to all
2,839
I cannot answer first two questions...... when you say you release the key, it stops....is it running when the key is in the start mode?
Have you bleed the lines? cracked the injector or injector "nut" ?
Might have a pump that is bad, but if you crack an injector ...it should push fuel out....and if not, then...........
fuel solenoid working correctly????
When did it run last? and what happened lately to create this problem?
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I'm going to guess you need to bleed the lines. I say this because you mention a clean filter. Likely gravity feed and no solenoid.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
A B6100 does have a lift pump. It is on the right side of the engine between the fuel filter and the injector pump.
