B6100 hydraulic pump
Billydesoto
B6100e
May 28, 2020
Gulfport, Ms
My B6100 hydraulic pump is pumping very weak and will not lift the 3point hitch. I removed the pump and the seal on the shaft that goes between the pump and the injector pump was coming apart. I wouldn’t think this would have anything to do with the pump not working. I had check the filter and clean it. Any advise on what to look for for my problem.
5,128
933
Often a "weak" pump is a consequence of a suction side air leak.
Suspect any rubber hose or joint on the suction side of the pump.
