Hello I have a B6000E and I have diesel/oil leaking from around both injectors.. I replaced one injector gasket and it didn't fix the problem.. the injector seems to have a loose fit.. would that be the injector(s) or the head causing that? What originally caused the problem is I flooded the engine and it revved out of control. after that I started seeing smoke and small amounts of diesel coming from around the front injector. it ran for a few times after that, and now won't start at all. then today I noticed the rear injector is also leaking diesel any ideas?
